New report: global cooling thru 2015
Forums Home | Domestic Fires | Environment
Posts 1-20 of 21 | Latest Post
First 1 2 Last
May 5, 2008 10:09 PM    View printable version     Link to this comment
February 24, 2007
From the Desk of:
Steve Elliott, President, Grassfire.org Alliance
5/5/2008
The latest "computer models" from global warming scientists
show that global warming will be in retreat at least until 2015.
Combined with the fact that there has been no global warming
since the peak year of 1998, even Climate Alarmist scientists
are being forced to recognize that we could be looking at
nearly a two-decade hiatus from global warming.
For the record, here's the history of global warming back
to 1940 and projected through 2015:
          1940-1974 (34 years) -- global cooling
          1975-1998 (23 years) -- global warming
          1999-2015 (17 years) -- temperatures level then cool
Go here to access a report on this new study:
http://www.grassfire.net/r.asp?u=6785... />
+ + Update on the $1.2 Trillion Carbon Tax
Unfortunately, the reality of this new data hasn't even slowed
down the Climate Alarmists who are pressing to pass their bill
next month.
In fact, I just got off a strategic conference call with our
Capitol Hill contacts who informed me that the Al Gore Tax
bill is still slated for a vote in early June. We fully expect
the Senate to vote on this $1.2 trillion Al Gore Tax before
the first day of summer.
         Please forward this message to your friends and urge them
         to join you in signing the petition by going here:
Thank you once again for taking a stand to stop Al Gore's climate
alarmism and the $1.2 trillion tax.
Steve
May 6, 2008 03:00 AM    View printable version     Link to this comment
May 6, 2008
Never trusted Al Gore when he was hooked up with Bill Clinton, Claiming he was quiting the tabaco Industry.  I've always said as long as he can wield any kind of power, this country will see the day when every one is starving and the world will be over run with fat happy spotted owls.
May 6, 2008 07:05 AM    View printable version     Link to this comment
February 9, 2008
Welcome to FS, Bird Man.
Time will tell who's right.  I suspect it will not be big Al.
2 Chronicles 7:14
May 6, 2008 08:44 AM    View printable version     Link to this comment
May 16, 2007
Comment updated May 6, 2008 08:46 AM
OMG!  The sky is falling!  Again!
Wink
Tell me again, what is a carbon credit worth?  Sounds like we need to ramp up the burning of fossil fuels!  Better buy your goosedown and wool while you can before the government steps in!
"There is only one difference between a bad economist and a good one: The bad economist confines himself to the visible effect; the good economist takes into account both the effect that can be seen and those effects that must be foreseen." -- Frederic Bastiat (1801-1850) "In general, Democrats are the only real reason to vote for Republicans." -- Thomas Sowell FeedFwd: a born again coonass trapped in Austin, TX, USA
May 6, 2008 09:46 AM    View printable version     Link to this comment
April 25, 2008
Subject: The Global Warming Scam
Beware The Scam by Al Gore, the United Nations Assembly and all other Idiots Around the Globe On Their Side of This Issue
The Truth About The Global Warming Scam
First of all, my knowledge of Earth's 'wobble' was learned while working as a  Field Engineer with IBM’s Federal Systems Division, providing both operation and field maintenance support for the radar bombing and navigation computer system installed on B-52 aircraft (1958 - 1963).  The field services were provided to Strategic Air Command Bases, firrst at Walker AFB, Roswell, NM,  then Columbus AFB, MS. The learning was impressed while at Columbus Air Force Base with the 4228th Strategic Wing.  Out of fifteen assigned B-52’s, we were launching three aircraft each day on 24-hour missions, flying the Operational Airborne Alert to and from the Arctic Circle, loaded with Hydrogen bombs, ready to wipe the Soviet Union socialists off the face of the Earth.
    B-52s (F-Models) at Columbus AFB were equipped with the MD-1 Automatic Astrocompass System,  to provide required aircraft heading by locking on to the light intensity of stars pre-selected  by the Navigators for their  crew's flight missions.  This MD-1 System was an analog computer; a  combination electro-mechanical and electronic computer  designed to solve the 'Celestial Navigation Problem'. (The MD-1 was designed and manufactured by the Kollsman Instrument Co. located at Hershey, PA at the time.)
    Now, about Earth's 'wobble', as follows:
Our planet Earth has two physical motions that drive our calendar to account for years, months, and days, and the seasons of Spring, Summer, Autumn and Winter:
1.    Duration of one counter-clockwise spin of Earth on its axis gives us one day with a Sunrise in the East and a Sunset in the West.
2.    Its spin axis tilted at 23.5 degrees away from the Sun, duration of one elliptical orbit of Earth around the Sun occurs over an elapsed period of time called a 'year', causing changes of weather during each of the four seasons of any given year.
Ques: Why, in its elliptical orbit around the Sun, when Earth is 3 million miles closer to the Sun, is it colder (Winter) in the Northern Hemispere, while it is warmer (Summer) in the Southern Hemisphere?
Ans: Due to Earth’s spin axis constant tilt at 23.5 degrees away from the Sun, the angle of incidence of parallel radiation of light and heat from the Sun is less direct in  the Northern Hemispere, causing the frigid conditions in the Northern Hemispere; at the same time, that radiation is more direct in the Southern Hemisphere, causing the heat of summer in the Southern Hemisphere. Continuous orbit of Earth around the sun causes reverse of those conditions in both hemispheres.
A third motion of Earth gets little or no attention for its effects on global warming and global cooling (recurrent ice ages).  Spinning like a top, tilted at a constant 23.5 degrees away from its elliptical orbit around the sun, the Earth has a wobble – that wobble is like decay of the spin axis of the spinning top.  One Earth wobble is measured to require roughly 26,000 years (25,800 years) to complete its duration.
Inclination of Earth’s spin axis to its orbital plane varies over 40,000 years by about 1 degree.
As Earth revolves about the sun and spins on its axis, an imaginary line runs through both the north and south poles of earth pointing to Polaris, the North Star. Earth's wobble causes the spin axis to trace a small circle in the sky. (Earth's lines of latitude and longtitude are projected on the sky, providing a 'celestial sphere' for locating all stars, planets and galaxies.) In 1500 AD, Earth's spin axis was pointing through the North Pole marking the North Celestial Pole at 3.5 degrees from Polaris. In 2100 AD (our next century), Earth's spin axis will be pointing to the North Celestial Pole at only .5 degrees from Polaris, the closest that the spin axis of earth will ever point to Polaris. About the year 14000 AD, the spin axis of earth will be pointing within 5 degrees of Vega, and Vega, not Polaris, will be the North Star at that time.
In the jargon of celestial navigation and astronomy, Earth's wobble, as just described, is called "precession of the equinoxes" - I call it the 'wobble'. In effect, Earth's wobble causes the climate in Florida to migrate to Michigan and back again over a period of roughly 26,000 years. Changes in weather patterns effecting climate conditions are a consequence of this very slowly moving migration. Responsible scientists know this information and readily admit we are in a warming trend. Recent reports tell of evidence of vegetation found in Greenland. Earth's wobble - like decay of the spin axis of the spinning top - not CO2 (carbon dioxide), is the cause of the recurrence of ice ages, and is currently at the root of causes during this current cycle of global warming – to be followed by another cycle of global cooling.
Bernard Palicki
Huntsville, AL
May 6, 2008 10:12 AM    View printable version     Link to this comment
May 24, 2007
Bernard,
Thanks, that is a more thoughtful explanation than all U.S. Citizens should give up their quality of life and become poor through choking and binding regulations administrated by a world body.   I have never believed " Climate Change" was any more than another tool like NAFTA, GATT, KYOTO, FOREIGN AID to bring the economic dependency of free U.S. citizens to mirror that of nations with oppressive leadership in government.     Bring down the middle class to complete dependency on government and merge all of us into global government.    Some people like McCain, Barak Hussein Obama and Hillary who have not thought it through completely actually think that is a good idea.
TG
John 16:33
May 6, 2008 12:24 PM    View printable version     Link to this comment
February 16, 2007
Comment updated May 6, 2008 12:26 PM
I sent this to one pair of my kids early last week:
Next question - - do you have an idea why the gas prices are up. We have massive oil fields here in this country that are not being tapped – partly due to the elitist environmentalists - - - that would last us an estimated 300 years. God is going to create a “New Earth” long before that.
But think about this. If gas prices keep where they are or even higher then “we” will have to make some changes. We are the only country on the globe where you actually see utility vehicles and pick-up trucks and the larger more comfortable cars that are good for travel. Since we have not been successful in getting markedly better gas mileage in these – the higher gas prices are encouraging many to choose the mini-sub-compact (like in Europe). That means that we cannot get as much in our vehicles - - we can haul less, and they are less comfortable. That means that travel would be less desirable over any distance and we would have less of an opportunity to travel across country without roads. Guess what that means to the government - - more control and ability to keep tabs on us! It makes sense – doesn’t it? Darn those global elitists anyway - - them and the friggin liberals. Yuk and ugh!
We must use our brains and not just accept what the liberals and the colleges tell us to think.
Think about it and get back to me, - ok?
Pixie
"The Second Amendment is the RESET button of the United States Constitution." — Doug McKay
May 6, 2008 01:48 PM    View printable version     Link to this comment
February 9, 2008
Well, they have us where they want us.  We are urged to buy those itty bitty foreign cars, we are to use less of everything, love our lettuce but not our cows, hug our trees and worship little flies somewhere.  This isn't just communism, this is getting very close to a dictatorship.  Free will and free speech is good for only some of us, usually the weird ones, and we better watch out and not speak up.  You never know where the next lawsuit is coming from.
And yes, I agree with all of you, except big, rich Al of course.
Welcome to all the new ones here. We need you.  There is strenght in numbers.
2 Chronicles 7:14
May 6, 2008 01:50 PM    View printable version     Link to this comment
February 9, 2008
bpalick said: Subject: The Global Warming Scam
Bernard Palicki
Huntsville, AL
You coulda just said Al is full of it.Wink This is almost too much for my little brain, almost.  Great article.
2 Chronicles 7:14
May 6, 2008 01:52 PM    View printable version     Link to this comment
February 13, 2007
Oh crap...........my carbon credits are gonna tank...................
 Think it has anything to do with the sun ? ? ? ?
May 6, 2008 01:59 PM    View printable version     Link to this comment
February 9, 2008
It's either the sun or too much cow poopoo.Embarassed
2 Chronicles 7:14
May 6, 2008 02:10 PM    View printable version     Link to this comment
February 16, 2007
bpalik - I copied your post and sent it to the same pair of offspring.  My daughter-in-law is in college studying for her Dr.'s degree and I'm afraid that every so often she absorbs some of the brainwashing from some of those professors.  Thus it is that I launch a campaign of sending accurate data  to try to get the cogs working again.  Thank you for your post!
May 6, 2008 02:13 PM    View printable version     Link to this comment
February 16, 2007
Comment updated May 6, 2008 02:15 PM
elaina -
By the way - you do know what our early pioneers coming west used the cow patties for, don't you. Collect them and dry them and burn them, and they make an excellent hot fire for warmth at night. Wonder what our elitist enviornmentalists would do with that??
Pixie
May 6, 2008 02:32 PM    View printable version     Link to this comment
May 16, 2007
One of my classmates did his senior project on just that... Cowpoo fueled boilers.  Mine was very similar, but I looked at other sources of refuse.  Try finding thermodynamic data on cow patties!
Wink
May 6, 2008 02:49 PM    View printable version     Link to this comment
February 16, 2007
FF -
I would imagine that would have to be scientifically tested - currently.  Don't think they were concerned with that type of data when they were actually using them.  Remember not to collect them too soon for testing,  the older ones are easier to handle as long as you get them before the flies do.
pixie
May 6, 2008 02:55 PM    View printable version     Link to this comment
February 9, 2008
Patriot's Pixie said: bpalik - I copied your post and sent it to the same pair of offspring.  My daughter-in-law is in college studying for her Dr.'s degree and I'm afraid that every so often she absorbs some of the brainwashing from some of those professors.  Thus it is that I launch a campaign of sending accurate data  to try to get the cogs working again.  Thank you for your post!
I loved your earlier post to your offspring.  My words exactly.  And yes, PP and FF, I do have some idea as to the use cow poopoo.  In July  in SD they will use it for Bingo i have been informed.  One will place the likeness of certain Politicians in the afore mentioned excrements.  The possibilities are endless.  I know that all of these wonderful past and present ideas are not welcome to those who buy into global warming.  For one, cows give off too much methane gas, and to think that one could burn the patties to keep warm just doubles the trouble.  And when people eat cows, well, the cows have to be cooked to a crisp these days, ergo more global warming.  Not to mention flatulence after indulging in these delights.  You see, we are far better off letting the Chinese finish the job, all in the name of compassion, for they are such a poor people, while we stick our heads in the sand, hoping to suffocate, and therefore not leave any more CO2 than we absolutely have to.  Unless we consider decomposition..............what to do, what to do, they sky is falling........................................................
2 Chronicles 7:14
May 6, 2008 03:07 PM    View printable version     Link to this comment
February 5, 2007
The trick is, to eat them quickly before they f*rt.... Mad Cow    That Stinks
"Good fences make good neighbors."-Robert Frost "Too BAD!!"-Glenn Beck
May 6, 2008 03:13 PM    View printable version     Link to this comment
February 9, 2008
I guess I deserve that one.  I should edit before I send.
2 Chronicles 7:14
May 6, 2008 03:40 PM    View printable version     Link to this comment
February 13, 2007
Where I grew up they were referred to as 'prairie muffins'.
We played prairie muffin frisbee, prairie muffin shuffleboard, used them as bases for prairie muffin baseball......................etc........I was so deprived as a child..................
May 6, 2008 03:49 PM    View printable version     Link to this comment
February 9, 2008
Bet ya had more fu than the kids nowadays.  My childhood friend and I did many extensive studies as to the many uses of these fine excrements, and came to the conclusion that God is very wise indeed.
2 Chronicles 7:14
First 1 2 Last
You must login to discuss this item.
